このウェブサイトでは、Cookieを使用しています
当サイトでは、Cookieにより当サイトの閲覧に関する情報を収集しています。当社では、ポリシーにより皆様のプライバシーの尊重を重視しています。当社プライバシーポリシーおよびCookieポリシーの詳細情報は、別セクションにまとめてあります。当サイトの閲覧の継続に当たり、ご利用条件への同意をお願いいたします。ご理解ありがとうございます。
A-ES Series
(Americas Only) 5-9.6 kW | Split phase | up to 4 MPPTs | Hybrid inverter (HV)
PDFダウンロード >>
スクロール
The GoodWe A-ES seies is a split-phase hybrid inverter designed to increase self-consumption of your generated solar energy. GoodWe A-ES is compatible with high voltage (80-495V) batteries with a power capacity ranging from 5 kW to 9.6 kW. With up to 4 MPPTs, the A-ES inverter seamlessly adapts to complex residential rooftops. Equipped with rapid battery charge functionality and perfectly capable of powering large loads in back-up mode (up to 9.6 kW).
Optional AC bypass switch
4 MPPTs & 150% DC input oversizing
Integrated AFCI & rapid shutdown
In-built smart meter
Integrated AFCI & Rapid Shutdown
The GoodWe A-ES has been designed to meet the safety regulations of the American market, including Arc Fault Circuit Interrupter and Rapid Shutdown. GoodWe does not only deliver efficiency, reliability, but security as well.
4 MPPTs & 150% DC Input Oversizing
Up to 4 MPPTs, the A-ES (5-9.6 kW) is the perfect solution to feed solar power to large residential properties, covering all the corners of your rooftop and maximizing total solar generation. With 150% DC input oversizing capability, the A-ES series is driven to its full capacity by extra reflections added to the back of bifacial panels, designed to increase power output even under low solar radiation.
4
UP TO 4 MPPTS
150%
DC INPUT OVERSIZING
GW5000A-ES
80~495
Max. Charging Current(A)
50
Max. Discharging Current (A)
50
Number of MPPTs / Strings per MPPT
Output Voltage Range (Vac)
211 to 264 @240
GW6000A-ES
80~495
50
50
211 to 264 @240
GW7000A-ES
80~495
50
50
4/1
211 to 264 @240
GW7600A-ES
80~495
50
50
4/1
211 to 264 @240
GW8600A-ES
80~495
50
50
4/1
211 to 264 @240
GW9600A-ES
80~495
50
50
4/1
211 to 264 @240
GOODWE Solar Academy データ保護 Declaration
ジョイトゥインストール
Goodweニュースレターを購読する
以下の詳細を挿入して情報を受信する
どのような種類のGoodweユーザーですか?
検証コード:*
私は善意を受け入れる プライバシーポリシー そして、私は条件を受け入れる
購読する
