このウェブサイトでは、Cookieを使用しています
当サイトでは、Cookieにより当サイトの閲覧に関する情報を収集しています。当社では、ポリシーにより皆様のプライバシーの尊重を重視しています。当社プライバシーポリシーおよびCookieポリシーの詳細情報は、別セクションにまとめてあります。当サイトの閲覧の継続に当たり、ご利用条件への同意をお願いいたします。ご理解ありがとうございます。
A-MS Series
5-9.6 kW I Split phase I Up to 4 MPPTs
PDFダウンロード >>
スクロール
The A-MS is an inverter of the highest quality and we take great pride in it. This product was conceived to be a solid element of your residential array for the long term. Put your faith and confidence in its quality, its extended warranty of 10 years and GoodWe will be on your side for any issue along the way.
Compatible with bifacial panels
95V start-up voltage
150% DC input oversizing
Integrated AFCI & rapid shutdown
Integrated AFCI & Rapid Shutdown
The A-MS has been designed to meet the safety regulations of the American market, including Arc Fault Circuit Interrupter and Rapid Shutdown. GoodWe does not only deliver efficiency, reliability, but security as well.
High Power Generation
This inverter goes with the trends of the North American residential market and is compatible with bifacial modules. It also has the capacity to take as much as 12.5 A per string. These features ensure that the A-MS can absorb more solar power and make it one of the most productive inverters on the American residential market. With a start-up voltage of only 95 V, the A-MS is capable of generating solar power earlier than competitors, remaining productive for a larger portion of your typical day. With 150% DC input oversizing capability, the A-MS allows end-users to significantly expand the solar array and drive increased power output even under low solar radiation.
GW5000A-MS
Max. Input Voltage (V)
12.5/12.5
Number of Strings per MPPT
1/1
Nominal Output Power (kW)
5
211 to 264 @240 / 183 to 229 @208
GW6000A-MS
12.5/12.5
1/1
6
GW7000A-MS
12.5/12.5/12.5/12.5
1/1/1/1
7
GW7600A-MS
12.5/12.5/12.5/12.5
1/1/1/1
7.6
GW8600A-MS
12.5/12.5/12.5/12.5
1/1/1/1
8.6
GW9600A-MS
12.5/12.5/12.5/12.5
1/1/1/1
9.6
ニュースレター
GOODWE Solar Academy データ保護 Declaration
ジョイトゥインストール
Goodweニュースレターを購読する
以下の詳細を挿入して情報を受信する
どのような種類のGoodweユーザーですか?
検証コード:*
私は善意を受け入れる プライバシーポリシー そして、私は条件を受け入れる
購読する
