このウェブサイトでは、Cookieを使用しています
当サイトでは、Cookieにより当サイトの閲覧に関する情報を収集しています。当社では、ポリシーにより皆様のプライバシーの尊重を重視しています。当社プライバシーポリシーおよびCookieポリシーの詳細情報は、別セクションにまとめてあります。当サイトの閲覧の継続に当たり、ご利用条件への同意をお願いいたします。ご理解ありがとうございます。
XS Series
0.7-3 kW | Single phase | 1 MPPT
PDFダウンロード >>
スクロール
The brand new XS model from GoodWe is an ultra-small residential solar inverter specifically designed to bring comfort and quiet operation as well as high efficiency to households. Its capacity ranges from 0.7 kW to 3.0 kW and its most outstanding characteristic is light weight, which is only 5.8 kg and as well as its extremely compact size equivalent to an A4 paper, that make it particularly easy to carry & install.Remarkably, it offers a 130% of DC input oversizing and it's able to achieve a maximum European efficiency of 97.2%. Conveniently, the communication options available on this inverter are both LAN and Wi-Fi.
A4 size
Light weight
130% DC oversizing
97.6% Max.efficiency
110% AC overloading
40V start-up voltage
A4 Size,Super Light
Compressing 3 kW DC/AC transforming technology into an A4 size inverter is unbelievable. However, GoodWe did it! Weighing less than 6 kg, inverters can be easily installed! Additionally, it also significantly reduces shipment and stock cost.
LAN/Wi-Fi Communication
An optional LAN/Wi-Fi communication offers customers different monitoring methods to cater for different needs. Customers are able to choose the most convenient way to monitor their solar systems. It also allows the customer to switch into another monitoring method after installation. GoodWe cares about your feelings and experiences.
Small, Light, Compact and Capable!
Even though the XS Series is extremely compact and tiny, it doesn’t mean standard features are sacrificed.
The XS is still equipped with 130% DC oversizing capability which allows full load output during extreme weather conditions and what’s more, its European efficiency can reach 97%, which is even more compared to its predecessors.
97.2%
EUROPEAN EFFICIENCY
GW700-XS
Max. Input Voltage (V)
500
12.5
Number of Strings per MPPT
1
Nominal Output Power (kW)
0.7
230
GW1000-XS
500
12.5
1
1
230
GW1500-XS
500
12.5
1
1.5
230
GW2000-XS
500
12.5
1
2
230
GW2500-XS
500
12.5
1
2.5
230
GW3000-XS
500
12.5
1
3
230
ニュースレター
GOODWE Solar Academy データ保護 Declaration
ジョイトゥインストール
Goodweニュースレターを購読する
以下の詳細を挿入して情報を受信する
どのような種類のGoodweユーザーですか?
検証コード:*
私は善意を受け入れる プライバシーポリシー そして、私は条件を受け入れる
購読する
